查看: 450|回复: 0
奔驰GLA改装 AIRBFT气动避震现场施工
发表于 2021-4-6 16:24:27 | 显示全部楼层 |阅读模式
On site construction of Benz gla modified airbft pneumatic shock absorber
奔驰GLA是一款趋于新A级和GLA概念车之间的车型,更像是一款跨界车型。而其动感时尚的造型,在加上简洁不失科技感的内饰以及配置,都基本符合了消费者对于跨界车型的审美观。
对于它有望被国产上市的消息,从价格方面就会有不小的优势,这无疑对于消费者比较利好,又多出了一个选择空间。但是此款车型是否能够在国内竞争激烈的SUV市场赢得一席之位,只能看其国产上市后的表现。
Mercedes Benz gla is a model that tends to be between A-class and GLA concept cars, more like a crossover model. Its dynamic and fashionable shape, together with its simple and technological interior and configuration, are basically in line with consumers' aesthetic standards for crossover models.
As for the news that it is expected to be listed domestically, it will have a big advantage in terms of price, which is undoubtedly good for consumers and gives them another choice. But whether this model can win a seat in the domestic competitive SUV market depends on the performance of its domestic market.
奔驰GLA改装气动避震低姿态案例在国内很少,因为属于一种另类的改装风格,不过改装就是要剑走偏锋,选择与众不同的风格,方能一鸣惊人!奔驰GLA改装气动避震悬挂开始施工,期待落地后的完美效果!
There are few cases in China that Mercedes Benz gla refits the low-profile pneumatic shock absorber, because it belongs to an alternative refitting style, but the refitting is to take a different style and choose a different style to make a big splash! Mercedes Benz gla modified pneumatic suspension started construction, looking forward to the perfect effect after landing!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system. It is actually similar to air shock absorber The principle is very similar to the common shock absorber, coil spring + shock absorber, except that by changing the volume of the air chamber (up and down direction), the distance between the car body and the ground can be adjusted, and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the vent hole of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance Performance, huh! So confident!
